Thermaltake Shark PC Case
Cygnus_x_1 (Cygnus_x_1) The Thermaltake Shark is one of the handful of Full Tower cases under the Xaser line of chassis' and was a pleasure to work with.
June 7, 2005 9:10 PM ET in Articles
Supplied by Thermaltake
Thermaltake has come along way from releasing their first heatsink in 2000 the Golden Orb. They slowly built upon their success in the cooling market adding water cooling, power supplies, chassis and computer accessories. With case modding now mainstream chassis manufacturers are constantly trying to stay ahead of the curve by releasing cases with innovative features and stylish designs that enthusiasts can build upon while also appealing to the masses.
frt
The Thermaltake Shark is one of the handful of Full Tower cases under the Xaser line of chassis’. Full tower cases usually have four to six external 5 1/4″ drive bays and two to eight internal 3 1/2″ drive bays. The Shark PC case brings five external 5 1/4″, two external 3 1/2″ and five internal 3 1/2″ drive bays to the party as well as a host of other features as the specifications detail.
Specifications
Case Type Full Tower Chassis
Side Panel Honeycomb See-through side panel
Net Weight 6.8 kg (14 lbs)
Dimensions 540 H x 205 W x 500 L (mm)
Cooling System 120×120x25mm intake fan, 1400 rpm, 21dBA 120×120x25mm blue LED exhaust fan, 1400 rpm, 21dBA
Material Chassis: 1.0 mm Aluminum Front: Plastic Bezel, Aluminum door
Drive Bays External: 5×5.25″, 2×3.5″ Internal: 5×3.5″
Expansion Slots 7
Motherboards Removable motherboard tray fits Micro and Standard ATX
USB & Firewire Dual USB 2.0, IEEE1934 Firewire, audio and speaker ports
Features
  • Removable motherboard tray
  • Dual 120mm fans in front & rear
  • Fits Tt liquid cooling system (performance radiator with 120mm fan) or any other specific brands
  • See-through side panel with EMI shield
  • Security lock on front door and side panel
  • Retractable foot stand
  • Tool-less design
The specifications reveal that the Shark is a feature-rich PC case.
Most notable are the 12 drive bays, a removable motherboard tray, dual 120 mm. fans and a tool-less design. Keep in mind that tool-lees refers mostly to maintaining the case once motherboard and drive rails are installed.
The door of the Shark makes up a good portion of the total case weight. It is constructed of heavy duty aluminum which incorporates the shark “fin” design. The chrome grill work is purely aesthetic as are the louvers on the bottom of the panel. A blue LED sits behind the upper left panel of the cut out that is visible when the case is powered on.
frt_lit
Behind the door are the five 5 1/4″ and two 3 1/2″ external drive bays. That is more than enough for a pair of burners as well as any monitoring panels and fan controllers. The possibilities are endless. The standard fare power and reset buttons are located next to the 3 1/2″ drive bay. I really wish someone would implement a reset button that wouldn’t require fingers the size of toothpicks to reset. Below that the bezel is slotted to allow the 120 mm intake fan to breathe.
bezel_lg
Thermaltake went with dual magnets to ensure the overweight door closes securely. There is also a keyed lock (same as the side panel below) if you feel the need to keep prying hands from accessing the case.
door_mag
Thermaltake chose to go with a Honey-comb left side panel instead of the traditional Plexiglas window. While it gives the Shark a unique look, the open design allows the possibility for more dust to get into the case. The latching mechanism is simple and works well. The addition of a second lock allows for total lock down of the Shark PC case.
side_1
Moving to the rear of the case the prominent feature is the 120 mm exhaust fan. It is a blue LED fan that comes to life once the case is powered. The combination of the 120mm intake and exhaust fans makes for rather good airflow, as well as a relatively quiet PC.
rear
Taking a closer look at the back panel reveals a bracket at the upper most right corner for a water cooling reservoir. Also there are 10 stamped punch outs to accommodate 3/8″ OD tubing for future routing of water cooling tubing should you want to experiment. Included in the box of various mounting screws are the plastic grommets to prevent the case from cutting into the tubing when installed. While this makes routing the tubing very easy, you are limited to puny 3/8″ OD tubing. It would have been nice to see varied sizes to accept tubing up to 5/8″ OD to support the higher end water cooling components.
wc_1
wc_2
The right side of the case is standard fair with the exception of the door lock and user friendly ports towards the front of the case.
rt_side
On the right side of the case are audio out,and microphone jacks, one Firewire port and two USB 2.0 ports. They can be connected to your motherboard via the cables inside the case.
frt_port
Inside the Shark PC case more than enough room for the average to advanced pc user. All of the edges are rolled so you don’t have to worry about keeping the first aid kit nearby when installing or maintaining your components.
inside_lg
Thermaltake utilized sideways mounted 3 1/2″ drive bays. The orientation makes installing and swapping out hard drives a breeze. Unfortunately, cable routing for the drives can become a chore with the loss of the ‘hiding spot’ that traditional drive bay alignment affords.
drv_bay
The hard drive trays include rubber shockproof pads with EMI grounding for installation. The pads also reduce the vibration of the hard drives that is usually transmitted to the case.
hdd_bot
hdd_top
Mounting of the drives requires special screws that are included with the case. The screw incorporates a spacer that passes through the rubber pad and allows any movement to be absorbed by the pads and not the case. Enough are included to mount five hard drives.
screw
Here is the hard drive mounted in the drive tray (upside down to show the drive tray).
hdd_inst
Two additional external 3 1/2″ drive bays are located above the five internal 3 1/2″ bays as well as the five 5 1/4″ bays.
cd_bay
The two external 3 1/2″ bays are removable as a single unit.
drv_cg
With the aluminum faceplate removed a floppy can be mounted with the included screws.
cage_inst
Rails for the 5 1/4″ drives are located behind the faceplates to keep things tidy.
rail
5 1/4″ devices are mounted with the included screws as well.
rail_inst
With plenty of room available there should be no problem installing the most demanding power supplies available today. Chassis bracing runs the length of the case to support the power supply and add rigidity to the case.
psu
Interior shot of the 120mm blue LED exhaust fan.
exhaust
The Shark PC case uses tool less PCI card clip for mounting of the video card and any PCI cards.
pci_1
An upward pull on the green lever disengages it from the case.
pci_2
The option is available to mount the cards with screws as well.
pci_3
The removable motherboard tray fits Standard and Micro ATX motherboards. It is held in by two thumbscrews and a sliding track system.
mobo_tray
It is a snap to install the motherboard with the tray removed.
mobo_inst
The last feature inside the case is the front port and bezel cabling. Starting with the standard motherboard power connectors.
power
Followed by the Audio, Firewire and USB 2.0 connectors.
frt_prt_cnt
Hidden behind the front bezel is the 120mm intake fan and filter. Releasing the six mounting tabs allows for the bezel to be pulled away from the case to reveal the fan.
frt_bare
It is nice to see that Thermaltake includes the filter.
int_filt
The only inconvenience is having to take both side panels off as well as the bezel to remove and clean it periodically.
itk_fan
filt_1
Installation
With the drives installed and the motherboard mounted you can now put screwdriver away and enjoy the tool less design of the Shark PC case. The 5 1/4″ drives install on the rails and click into place.
cd_mnt
The 3 1/2″ drive cage does the same.
cage_mnt
Moving inside the case the motherboard tray mounts on the track and gets secured by the two thumbscrews.
mobo_instld
The video and PCI cards get installed and the PCI card clips holds them securely.
card_clip
The hard drive installation is as simple as sliding the drives in until they click into place.
hdd_mnt
The power supply mounts with the included screws. I chose to mount it with thumbscrews.
psu_inst
Cabling in the Shark PC case requires some creativity and a lot of trial and error to keep things tidy and the air flow optimal. This is still a work in progress.
cabling
frt
The Shark PC case from Thermaltake is a pleasure to work with. The interior layout leaves enough room to install and maintain the system easily. The side panel, and front door are designed tastefully, and would be at home at any Lan Party as well as in the living room. There are numerous features that make working with the case very enjoyable including the removable motherboard tray and tool less design. The intake and exhaust 120mm fans make the case itself almost inaudible. If you are looking for a quiet and stylish solution the Shark delivers.
frt_lit
Pros
  • Great design
  • Completely tool less chassis
  • Extremely quiet
  • Enough space to comfortably work inside
  • Able to upgrade to 3/8″ tubing water cooling system easily
Cons
  • Susceptible to dust due to the Honey-comb design of the side panel
  • Cabling nightmares
  • To clean the intake filter both side panels and front bezel have to come off
  • Limited to 3/8″ OD tubing water cooling with out cutting the case
Our thanks to Thermaltake for
their support of this and many other sites.
Highs
  • Great design
  • Extremely quiet
Lows
Scores Breakdown
Attribute Score Comments
Design & layout 9 Working with the Shark was a pleasure. There is plenty of room to work with and the tool less design makes maintenance a breeze.
Documentation 9 Manual supplied. Clear instructions.
Features & options 9 Feature packed case. More tubing size options would have warranted a 10.
Modding possibilities 8 Top window/blowhole possible.
Overclocking features 9 Geared for water cooling.
Presentation 9 Boxed well, features displayed on the carton.
Price / value 8 A bit pricey, but well worth it.
Total score 61/70 87.1%
3 Comments
  1. TheBaron
    i must say, that looks much better than the previous cases in the Xaser line.
  2. Unregistered
    Well I've touched this case before and it's all well and good and this review sums it up fairly except...it real flimsy. You never bring this thing out of the house.
    CaseCutter
  3. Great and steady case, I have cut a transparancy film so i have a window behind the honeycomb window. That keeps a lot of dust out. Only problem with the case is that the LED is right on top of the part where it's after. You will always look right in to the LED instead of the light of the LED. I thus have put a black sticky paper over the LED so it puts only the light in the right direction (the case) and not my eyes!
    In the points against the case is the nearly impossible way to clean the front filter. Solution: Turn PC off, get your vacuum cleaner. You'll know the rest.
Troll-free since 2003 ®
